Adhesives
Adhesive to make PSA sand discs
10/17/22
Greg Aanes
Website: http://nwchairs.com
I just discovered a large stack of sand discs paper backed, is there an adhesive we can use to turn them into PSA discs and utilize them?
10/19/22       #3: Adhesive to make PSA sand discs ...
In my opinion your only real option is to buy a wide roll of double stick from perhaps someplace like Fastcap. The problem is there isnt really a good readily available peel and stick options whether its spray or roll that gives good hold but allows removal without tons of residue. Most adhesives you will find are made to stick, not stick, then be un-stuck.
We have, in a pinch, tried a few different options and they either heat up in use and come un-stuck or peeling them off is a nightmare with residue.
As much work as it is to save a small amount of paper its best to either just use it up as hand paper or toss it.
10/19/22       #4: Adhesive to make PSA sand discs ...
Maybe try this
Krylon Easy Tack
10/31/22       #5: Adhesive to make PSA sand discs ...
Double backed carpet tape would work. I can't imagine it's worth the time and effort when you can buy Klingspor discs for less than a $1. They last a really long time and the H&L never fails. Unless you work in an autobody/boat shop and burn thru discs constantly, I have no idea why you wouldn't use hook & loop over adhesive back. I haven't used an adhesive disc in the woodshop since about year 2000. I threw the Porter Cable random orbits in the bin, switched to Bosch H&L and never looked back.
