Adhesives
adhesive for thermally modified hardwood like Cambia
12/1/22
Bill Z
Website: http://woodinnovations.net
A fellow woodworker says that since thermally modified hardwood does not absorb moisture, water based glue is not supposed to work. However he says that Tight-bond 3 will work if the clamp time is 24 hours.
Has anyone tested this? Epoxy is recommended but is expensive for a large project.
12/1/22       #2: adhesive for thermally modified har ...
I have successfully glued with type 2 pva such as Titebond 2 and urethane glue.
Thermally modified wood still absorbs water. You can check this by wipe a damp rag over the face and end grain.
2/16/24       #4: adhesive for thermally modified har ...
Angel17 Member
