Adhesives
How to clamp 4' x 8' sheets evenly
5/21/25
John S
I am looking for a way to clamp material to 4x8 sheets of plywood. The problem is trying to get even pressure across the sheets so it adheres evenly and doesn't bend during the dry times. I am planning to do up to 50 sheets at a time, finishing at 3/4". My current idea is to use ratchet straps over some angle iron or something similar to keep it flat. Any suggestions on equipment or ideas you may have would be helpful, thanks in advance.
5/21/25       #2: How to clamp 4' x 8' sheets evenly ...
Ken Member
Are you talking about gluing 4x8s to 4x8s or dimensional stock to the 4x8?
5/21/25       #3: How to clamp 4' x 8' sheets evenly ...
John S
Ken
We will be gluing 3"x48" pieces to the plywood. Maple to maple plywood.
5/23/25       #4: How to clamp 4' x 8' sheets evenly ...
Will a vacuum bag worK?
5/25/25       #5: How to clamp 4' x 8' sheets evenly ...
If this is a money making venture and not just a one off then you will need to invest in an hydraulic press.
You will have significant adhesive and wood movement issues to overcome as well as working out how to accurately place 36 pieces of maple on each sheet and get it into the press without shifting.
What you are trying to do is similar to hardwood flooring. To manage wood movement, flooring is fixed on one edge and the other is free to move in the tongue and groove. Engineered flooring is essentially plywood and can be glued down with a flexible adhesive - flooring mastik. You might consider that technique.
Do not glue down solid wood to the ply and expect it to stay flat. Read up on wood movement from moisture cycling. I recommend "Understanding Wood" by Bruce Hoadley or just read through the numerous threads here on woodweb.
I strongly recommend making a sample and running it through simulated environmental cycles to test the feasibility of the product.
You do not want to end up with fifty epensive maple potato chips on your hands.
5/27/25       #6: How to clamp 4' x 8' sheets evenly ...
John S
Tom
A press or something similar is what I am looking for recommendations on. Placement, glue, and wood are all things I understand well. What I don't know is what type of press or clamps are available for a project of this size
5/27/25       #7: How to clamp 4' x 8' sheets evenly ...
John S
David
I had not considered a vacuum bag, will look into that
5/28/25       #8: How to clamp 4' x 8' sheets evenly ...
Acctek  Member
Website: acctekcnc.com
A vacuum bagging system may be suitable for this project. The vacuum creates uniform atmospheric pressure across the entire surface. You can laminate multiple panels at once.
5/28/25       #9: How to clamp 4' x 8' sheets evenly ...
I do not think a vacuum press will be sufficient to ensure a flat pressing. I would look for a 4 X 8 hydraulic cold press. If you use a slow setting adhesive you could load multiple sheets at a time.
Here is a typical pod press with a large daylight that could handle your job.
https://woodweb.com/exchanges/machinery/posts/551587.html
5/29/25       #10: How to clamp 4' x 8' sheets evenly ...
Will Williamson  Member
I use the vacuum Table on my CNC to clamp 4 x8 sheets pulling 22 inches of Vacuum Works very well
6/8/25       #11: How to clamp 4' x 8' sheets evenly ...
BH Davis  Member
A 4x8 vacuum frame table is about as good a method as you can get for this. It will give you even pressure over the entire surface while keeping the plywood flat. You just have to have a way to make sure the parts applied to the plywood don't move during the pull down process.
This will give you 13 lbs of pressure per square inch at full vacuum pull down. I once put a piece of 3/4" particle board on top of the open end of a joint compound bucket as a base for a pressing operation and placed the assembly on our vac frame table. The vac pressure punched a 6" round hole in the center of the particle board.
https://veneersystems.com/product/flip-top-frame-49-inch-by-121-inch/
6/27/25       #12: How to clamp 4' x 8' sheets evenly ...
Poor Bunny Member
Using a vacuum bagging system may be an effective approach for this project. It ensures even pressure distribution across the surface and enables the lamination of multiple panels at once.
