Adhesives
EVA glue for edge banders
1/9/25
Armando Member
I wonder what type or brand other people using for their edge banders
I have a SCM K230 edge bander is a slow speed machine 9-m/min
50k-70k mpas / Viscosity at 185 degree / Year 2015
Glue pot 180 -200
I tried PO glue but my machine is slow speed and up to 200 degrees it did not work on my edge bander
I am having problems with the edge banding adhering properly to my materials and only have this problem during winter time. The building gets too cold because it’s all metal building without insulation.
I have used Jowat 280.30 and tried other glues and edge banding brands and still having problems in winter time.
My shop gets about 20 degrees cold and most of the glues is good for 50 degrees cold room temperature.
The day that I put the edge banding it holds good but in few days the edge banding peel right off.
I need to find a glue that will hold for a lower temperature room
I appreciate any advice.
Thanks…Armando
1/12/25       #2: EVA glue for edge banders ...
Bozzy Member
Does your edgebander have a panel heating device that is ahead of the glue pot? It's specifically made for your condition. I think they are turned off by default. This makes a big difference for us in the winter.
How big is your shop?
1/12/25       #3: EVA glue for edge banders ...
Armando Member
Bozzy,
Shop is 5000 sq ft
My edge bander does not have a heat panel device, I think the problem is the
shop that it's too cold because the same day that we run the edge bander we have no problem with the edge banding adhering to the materials.
The problem is after a few days the cabinets sit in the shop all day and night and that is when the edge banding, if you pull on it comes right off.
I am looking for a glue that will hold in a low room temperature
20 degrees F. o lower degrees.
1/12/25       #4: EVA glue for edge banders ...
Bozzy Member
Not sure what your volume is, but it seems like you need to start heating your shop. We spend about $1000/month to bring the shop temp to 50-55 when outside temp sits around 32.
1/13/25       #5: EVA glue for edge banders ...
Armando Member
Yes,
Looks like I need to do something to heat up the shop.
1/14/25       #6: EVA glue for edge banders ...
Matt Member
A nice diesel torpedo style heater will go a long way to helping you here.
Also make sure your edgeband isn't old. We throw away stuff that's over a year old. The primer on the back of edgeband goes bad, especially quickly in humid places like where I live. The $50 you save on a job isn't worth having a kitchen to redo.
1/28/25       #7: EVA glue for edge banders ...
Yeas Member
Your edge banding issues are likely due to your shop's low temperatures (20°F in winter), which are far below most adhesives' minimum operating temperatures. To address this, consider heating your workspace with portable heaters or insulating the building for long-term improvement. Switch to a low-temperature hot melt adhesive, such as a PUR glue like Jowatherm-Reaktant 607.40, which cures better in cold conditions, and ensure materials are preheated to improve adhesion. Adjust your glue pot temperature (if possible) and machine pressure settings to optimize bonding. Alternatively, consult adhesive suppliers like Jowat or Kleiberit for winter-specific glues and test flexible edge banding materials like Rehau. Warmer conditions and the right adhesive should resolve your issue.
2/6/25       #8: EVA glue for edge banders ...
Jim Member
I keep my shop at 60 in the day but when I run the bander before it heats up I use this heater to warm the edgebanding I make a small ten
https://www.amazon.com/gp/product/B0BDD39XWL/ref=ppx_od_dt_b_asin_image_s00?ie=UTF
8&psc=1t over the edgebanding It works good
https://https://www.amazon.com/gp/product/B0BDD39XWL/ref=ppx_od_dt_b_asin_image_s00?ie=UTF8&psc=1
5/4/26       #9: EVA glue for edge banders ...
Wally Robinett
The edgeband primer tip is something people overlook constantly — old stock sitting in a cold damp shop is a silent killer for adhesion. But at 20 degrees the real fix has to be the shop temperature. A torpedo heater gets you through the season without a massive investment, and prewarming your panels and edgeband before a run makes a noticeable difference even before anything else changes.
