Armando,
From the edge banding and adhesive side, I would treat this as a temperature/wetting problem first, not only a glue-brand problem. At 20°F the panel core, PVC tape, and glue line are all pulling heat out of the hot melt very fast. The edge can feel bonded on the day of production, but if the adhesive did not properly wet the back primer and board edge, the peel failure shows up after the parts sit in the cold shop.
A few practical tests:
1. Store the PVC tape and panels in a warmer area for a day before running, then run a small batch and peel test after 24-48 hours.
2. Check the age and storage of the PVC edge banding. The primer on the back of the tape matters a lot; old or damp stock can fail even with a good EVA.
3. Do not only raise the glue pot temperature. On a slow machine, too much heat can shorten open time and make stringing or poor transfer worse.
4. If the SCM has a panel preheater or edge warming option, use it. If not, prewarming the tape roll and panel edge is still worth testing.
5. PUR can help in some cases, but it is not magic at 20°F and it brings cleanup/storage issues. A low-temperature EVA or suitable PO may be easier if the machine speed and temperature range match.
For testing, mark tape age, glue, pot temp, shop temp, and panel/tape preheat condition on short samples, then peel them the next day and again after a few days. That will tell you whether the issue is glue, PVC primer, or cold material temperature.
Daniel Ni
Hangzhou Jinyou New Material Technology Co., Ltd.
PVC edge banding / EVA & PUR hot melt adhesive / PVC board materials
