Adhesives
Polyurethane Cleanup
11/13/25
GARY
Has anyone found a power tool that can cut off the squeeze out from Gorilla type glues after it has hardened ? Fein saw ?
Thank you !
4/16/26       #2: Polyurethane Cleanup ...
Quint Member
Polyurethane squeeze-out always feels harmless until it cures rock solid and suddenly nothing wants to touch it . I’d stay manual first — sharp chisel, card scraper, even a razor if access is tight. Power tools like a Fein can work but way too easy to overdo it. Same kind of thing I’ve seen in Phonexa — small oversights early turn into annoying cleanup later.
6/18/26       #3: Polyurethane Cleanup ...
For 50 years, my glue removal tool has beed a Red Devil Paint scraper. Sharpen it with a file, make you own handle, Pull at an angle for most glue removing, and even some wood removal.
However, with urethane glue, it works best if pushed along the joint/squeezeout.
