wall mountings, hardware for plywood -- 0 --
2/1
Is it possible to mount on the wall 12 cm (4,7 in) thick plywood shelf, which can hold 30 kg (66 lbs), mountings has to be hidden
View higher quality, full size image (951 X 535)
2/1 #2: wall mountings, hardware for plywoo ...
mistake-10mm thick and 12 cm wide shelf peace
2/2 #3: wall mountings, hardware for plywoo ...
pattern the face part then pattern an undersized "Cleat" to attach to wall, Fab shelf and slip it over "Cleat" on wall and attach from top Depending on size and weight for type of fastening and or adhesive
cleat.pdf
2/2 #4: wall mountings, hardware for plywoo ...
Theare is Also the "French Cleat" Method
French_Cleat.pdf
2/2 #5: wall mountings, hardware for plywoo ...
The only way I can see it working is to have mounting inside a bare wall so you can screw through that 10mm plywood into blocking, then make them plaster of drywall around the shelf.
2/6 #6: wall mountings, hardware for plywoo ...
Check this link. Scroll down to Shelf Magic I.
Shelf Magic
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
