Subject: Re: Wide Belt Sander 5' Wide?
5/6/14
Joe Wood  Member
Website: http://woodsshop.com/
I'm trying to find a shop in the San Diego area that has a 5' wide belt sander, and am not having any luck .. does anyone happen to know of one?
I have three, 1 1/2" thick, round window frame blanks I've glued up I need both faces trued up as they're going on to a CNC table and need to be flat
and one of them is 4' 10" wide.
if not, could someone show me a nice router sled setup for flattening wide pieces like this?
5/6/14       #2: Wide Belt Sander 5' Wide? ...
Can't you use the router to first flatten one side of the frame then flip and flatten and true the other side of the frame? Certainly faster then a manual router sled. The router should give you a flatter overall pc then a wide belt as the wide belt will not take out all the cup or deviations.
5/6/14       #3: Wide Belt Sander 5' Wide? ...
Use the router to knock the high spots off one side, shim it if necessary. Flip it route it flat then flip it again and do a final pass on the router.
5/6/14       #4: Wide Belt Sander 5' Wide? ...
Joe Wood  Member
hmmm, didn't think of having the cnc do it, probably leaves a nice finish surface with little sanding needed? If I did it by sled there would be lines all over.
5/6/14       #5: Wide Belt Sander 5' Wide? ...
Keith Newton
Joe, You are think of the wrong tool for your needs. I've got a 6 1/8 Makita power-plane that I would use, and have it done in short order. I've had it for ~30 years, which works out to have cost about $10 per year, got what i paid back then.
Makita on Amazon
5/7/14       #6: Wide Belt Sander 5' Wide? ...
The CNC router will not leave a slick finished surface because it is shear cutting. A jig and the Makita power plane seem like a good idea. Even if you need to buy the plane new. They cut really clean.
