Subject: Re: Rosewood lumber/veneer source
10/23/14
Eric Member
I have a job that calls for "Guatemalan rosewood" my research has shown it's perhaps more commonly known as "Honduran rosewood". The pictures of the original casework to be replaced show a more golden brown color than reddish. I'm in the dark here, any input would be welcome.
Thank You
View higher quality, full size image (972 X 1350)
View higher quality, full size image (1434 X 1350)
10/23/14       #2: Rosewood lumber/veneer source ...
John S  Member
It is definitely veneered panels, it is book & butt/end matched, you can't do that with lumber. I would try Bohlke Veneer or Sobo USA, both handle high quality exotic veneers. If you are going to do the veneer work (splicing & laminating) yourself, understand that Rosewood is very expensive and quite a challenge to work with.
10/23/14       #3: Rosewood lumber/veneer source ...
Charles Wright  Member
Website: http://www.northcreekwoodworks.com
If you want matched panels to the specific size you need or full sheets we can make them on a custom basis. Depending on the degree of matching to the photo you require, we can likely find what you want if it does not match the brown santos we normally stock.
10/23/14       #4: Rosewood lumber/veneer source ...
Eric Member
Thank you for the replies, There is hope the design will change to avoid the butt joints and have a more aesthetic and practical joint for onsite assembly.
10/23/14       #5: Rosewood lumber/veneer source ...
Eric Member
I should have added, yes the faces are veneer but the edges are solid lumber.
Also one idea floated by the owner was a solid top with inlaid butterflies at the butt joints, from what I have seen of lumber availability that's a non starter.
10/23/14       #6: Rosewood lumber/veneer source ...
John S  Member
I can think of a number of reasons why you wouldn't want to go with lumber. But I can pretty much guarantee that once the owner finds out what it will cost to do that in solid Rosewood lumber, they will lose interest (have smelling salts close at hand).
10/24/14       #7: Rosewood lumber/veneer source ...
mark
How old is the original, and why is it being replaced?
10/25/14       #8: Rosewood lumber/veneer source ...
Eric Member
"How old is the original, and why is it being replaced? "
I'm late to the party so don't have many details, unit is being remodeled, original casework was removed, replacement millwork was made by others but the "powers" are not satisfied with the quality and design. Things are still in the design stage.
