Subject: Re: fastening teak plywood to greenboard
12/2/14
jarod Member
Im about to rip 3/8" teak plywood into 4" strips with a small bevel on the edges and my question is 1. Do I need to apply ferring strips to provide an airspace between drywall and plywood rips? This is going on a ceiling in a bathroom with a shower.
12/4/14       #2: fastening teak plywood to greenboar ...
I would be more concerned that the proposed space would give the moisture a place to collect. You are describing a vertical drainage plane on the outside of a house for siding.
I would do a good job sealing both the green board with BIN primer and then a good job sealing the back of the teak ply. Maybe with Sealcoat.
