Subject: Re: methods for stable panel construction
8/11/15
Mahdi Member
I want to build some panels for a door and I'd like to reduce wood movement as little as possible.
there are some options for building. which one produce more stable panel?
is it possible to stop movement of the panel like plywood?
A.3 ply panel with quartersawn woods in the middle and 3mm face veneers.
B. 3 ply with 3 mm mdf core and 6mm shop sawn veneers.
c. 3 ply: 10 mm solid core and 3mm veneered mdf for both sides.
thanks
8/11/15       #2: methods for stable panel constructi ...
In my opinion, 3 maybe, but definitely 6mm cannot be called veneer because they are too thick and they will act like wood in seasonal movement, not veneer. Sanded to a final thickness of 2.4mm is about the thickest shop made veneer I make. You don't say what kind of door. Passage, exterior, or cabinet? No idea on size either.
8/12/15       #3: methods for stable panel constructi ...
Mahdi Member
thank you rich c.
my question is for general use of panel, but i more concerned about exterior door and cabinet door.
and you're right 6mm wood isn't veneer.
