Subject: Re: Stave Core Stiles & Rails
10/14/15
Gary
I normally build my stave cores out of the same material of my face veneer species but when it comes to Walnut I am hoping to find a less costly alternative. I could use strips of 3/4" plywood, douglas fir lumber, or commercially available LVL. The doors are interior stile & rail type. Any suggestions that come from positive experiences would be appreciated.
10/14/15       #2: Stave Core Stiles & Rails ...
Geoff
We use pine core, 1/8" skins, 11/16" edges.
10/20/15       #3: Stave Core Stiles & Rails ...
Gene Wengert - Wood Doc
I assume that because of your species choice that you are on the West Coast. Can you get low grade alder (cut the knots and steep grain regions close to a knot out)? A softer wood for core material is often the best choice. Pine is better than DF, for this reason. You can even buy solid lumber core (too expensive for you?). LVL is probably not the best option.
Lamination of the walnut to the core can require special attention.
Many people use an MDF core. Plywood is not uncommon, but plywood often likes to twist due to the grain angle within the sheets of veneer..
