Subject: Re: horizontal plank doors
1/31/16
Danny Member
I am looking to build interior 5 doors. They would like them to have horizontal planks, 4 to 5" tall, full width of the door. My current plan is to use a Baltic birch core, BB core engineered hardwood flooring for the planks, and then cap the ends with a piece of quarter sawn white oak, domino'd into the BB core to create a breadboard type end. End cap piece would be a T shape, the flooring would carry over it and the T shape would cap the raw end of the flooring, so there would be 1/2" of a "stile" exposed
3 of the doors would use traditional hinges. 2 are for pockets doors, which require a dado to be cut into the head to fit the trolley assembly for the door.
Will my bread board type style help keep this door flat? Is this a bad design overall? I have read many posts on vertical plank doors with numerous rails to create a ladder core. Is this a better method for this style of door?
2/1/16       #2: horizontal plank doors ...
You can think of door construction as two basic types - Frame and panel, with moving parts of solid wood that respond to changes in RH, or stable ply or other man-made parts that do not move, but still must live in a world where RH is not constant. You can mix the two as long as you do so coherently, for a reason.
Beyond that, this has been covered a few times in the last 2 years, so you might look in the Knowledge Base. 'Ladder core' doors has a discussion of how this works with vertical planks, along with some other methods.
2/1/16       #3: horizontal plank doors ...
Kevin Jenness
Given my experience with Baltic Birch over the years I would not rely on it to produce a stable door, "engineered" or not. I would stick with the proven method of a solid wood ladder frame, with all parts carefully selected and milled in a couple of sessions to allow culling of warped pieces and allowing space between the staves for expansion.
