Subject: Re: Cabinets concealed as wall panels
2/15/16
Ursula Member
This job has several recessed built in wall cabinets with front panels that are flush with the wall surface beside them. Some of the wall panels adjacent are painted plasterboard/drywall and some are plywood with a clear finish.
The design shows a small negative join between the wall panels, and the front panels to the cabinets are supposed to match this, with full overlay concealed hinges and push-to-open latches.
For the cabinets with a clear finish, to match adjacent wall panels, if I cannot get veneer to match the plywood used on the wall panels, will a thin matching ply, glued on a thicker MDF panel to form the door, address the issue of ply movement?
Some of these door panels are quite large: 2.4 m x 0.6 m. (8' x 2') What thickness of panel would be stable without being too heavy?
2/20/16       #3: Cabinets concealed as wall panels ...
Kilgore Trout
Cabinet doors meetting dry walled surfaces is never a good idea. The drywall is never as flat or true as the door panels, the corner bead is out of your control, and the paint wears badly. Flush is out of the question, recessed may be possible, but not good. There is a reason this is not seen.
I have seen it work when the adjacent wall is plywood or MDF. Then it is possible to have a door meet it.
2' x 8' doors should be torsion boxes in my opinion. It is not reasonable to expect single ply plywood of that size to not respond the the world it lives in. Doubling it in thickness will not help. Torsion boxes will give you flat at about the same weight as 3/4" ply, though should be about 1-1/4" thick or so.
