Subject: Re: Expansion of quartered sapele
9/19/17
Tim  Member
Website: eastmanwoodworking.com
We are building exterior doors with solid, quartered sapele panels approx 31" W X 1 3/8" Th. The material is KD and has been in climate controlled shop. I want to anticipate potential movement after installation. The doors will be painted with the panels' ends sealed. I would anticipate potential expansion of up to 3/8" and would like to leave 3/16" space on either side. We use splines then moulding to trim, covering splines and capturing the panel.
9/20/17       #2: Expansion of quartered sapele ...
Get several readings on your moisture meter now. Then go to the Shrinkulator - the online calculator to determine wood movement.
The science is there, your job is to get accurate values to plug into the formula.
Woodweb also has other calculators.
I have found that hardwoods are more likely to expand from my shop onward. That is, when I buy them they are at the low side 6-7%, and will gain a bit in the shop - 1-2%. Then when on site, interior work may increase more, to read 8-10%. If it is new construction with paint, concrete, open windows, no HVAC it will run to the high side. It does take a while to change - months.
Shrinkulator
