Subject: Re: grinder coolant
grinder coolant
9/4/18
Lynn Floyd
What coolant is best for use in a profile grinder? I grind high speed steel molder knives.
9/4/18       #2: grinder coolant ...
Russ
Website: http://mr-moulding-knives.com
Lynn
I have tested and used many grinding coolants over the years, currently Weinig make the best grinding coolant hands down. Acmosit 65-62 Ultra cool is the name, it is expensive but worth it.
You can by from Weinig direct or thru many authorized tooling supply companies, I am one of the many who can get this for you.
All the best
Russ @ Mirror Reflections
9/4/18       #3: grinder coolant ...
Lynn Floyd
Thank you Russ. I will try it.
9/4/18       #4: grinder coolant ...
Gary
What makes it the best?
9/4/18       #5: grinder coolant ...
Russ
Gary
Good question, here are a few things I feel makes it the best on the market, it just my opinion from many years of grinding moulding knives.
It keep the knives cool when grinding without any burning, does not allow rust to form on the machinery, any rust present on the machinery will dissolve over time. It's clear and easy to notice when the water needs replacing. Works well on carbide without any leaching of cobalt (red color water) which is a carcinogenic. No nasty smell when water needs replacing.
I hope that helps
Russ @ MR
