Subject: Re: Pivot Door Jamb
Pivot Door Jamb
11/16/18
Gary
I will be providing an entry door that will have a Dorma top mount closer/pivot hinge and the pivot point will be as close to the jamb leg as possible. I would like to use rabbetted jambs with no stop at the the top jamb ( I will use two rows of mohair there) .
Any downsides to this approach?
11/26/18       #2: Pivot Door Jamb ...
David R Sochar  Member
There is no given reason for eliminating the stop on the head of the door. I don't think it a good idea as the mole/mouse hair will not stop stiff winds.
Dorma and others make center pivots with concealed closers. These will easily allow a counterpoint just half the door thickness away from the jamb (for 90 degree operation).
You will need to monkey around with the hardware and rabbet placement on the hinge side of the door. Websites usually have great tech drawings.
