Subject: Re: Tall Stiles
Tall Stiles
7/10/21
Gary
I need to build some 12' tall doors and I'm wondering if anyone has had good luck with a particular type of stile? I'm thinking 3" thick X 6" wide for these. I am open to Engineered or?
Thank you
Gary
7/12/21       #2: Tall Stiles ...
BH Davis  Member
I'd say pretty definitely stave core construction.
7/14/21       #3: Tall Stiles ...
Some doors? How many - 2 or 20? What species? Why I ask, is can you get decent lumber at that length in solids? If so, that is the way I'd go.
If you can't get good solids reliably enough, then you could go to stave built (they are not engineered unless you plan on having engineers give them a stamp).
7/16/21       #4: Tall Stiles ...
David,
There are different levels of design. The cost goes up proportionally with the designer. Quality is generally irrelevant.
1. Cabinetmaker/woodworker
2. Interior designer
3. Architect
4. Engineer
Therefore an "Engineered" door will cost more. As well as be structurally more sound.
We build "engineered" and not stave core doors. Otherwise we could only charge the basic woodworking rate.
There is also Milspec, aircraft grade and NASA grade
We can't get away with using those in residential houses. I guess we need to find wealthier clients.
7/19/21       #5: Tall Stiles ...
I'd love to see what engineers have to say about 'engineered' stiles. I will bet lunch that your firm never paid an engineer to stamp your drawings. Not a slight against your firm, but just a reality.
This does not mean your stiles are suspect. As we all know, the proof is in the maker, over time.
I learned the AWI standards - Economy Grade, Custom Grade, and Superior Grade. Only after meeting some guys that did work for the White House, State Dept, etc, did I find out there is a 'Monumental Grade" that far exceeds the AWI standards.
I'd take Monumental Grade over "engineered" any day.
If you analyze the term "engineered", you realize it does not mean good or better or best, only that a stile has been stressed and observed. Yugos were engineered, but they were no better than a Lada - also engineered.
7/23/21       #6: Tall Stiles ...
David,
We’ve had this chat many times over the years. We always been on the same page. I was just having fun. We do solid or stave core. I’ve never called our product “engineered”. My favourite is “engineered”flooring.
My Dad was an engineer who designed subs at EB. He used to joke about mil spec and the like.
7/24/21       #7: Tall Stiles ...
nicko
You know what they say about engineers? They measure it with a micrometer, mark it with chalk and cut it with an ax.
nicko
