Subject: Re: Veneer in exteriors
Veneer in exteriors
12/14/23
Craig Caughlan  Member
Website: https://www.instagram.com/craigcaughlan/
For the facade of a store in a commercial mall project, that because of the mall design would be exterior, but with no direct exposure to sun or rain, in a mild environment, one option would be 3' x 4' panels of 1/16" quartered white oak veneer over 3/4" birch panels using resorcinol. The panels are then profiled with cutouts in the field (interior of panel) with CNC, reducing the surface area of the panel by almost 50%. Finished with an appropriate exterior WB finish. These panels are then mounted onto another panel.
Does anyone have experience with such an installation?
12/14/23       #2: Veneer in exteriors ...
Sounds like nothing but trouble to me. There will still be fog, condensation, and maybe frost and freezing? What about skate boarders and people leaning against it? Birch plywood has little weather resistance.
12/15/23       #3: Veneer in exteriors ...
Good questions but not applicable to the climate at 20°N/103W. And the facade is above door height. I think the birch ply can be sufficiently sealed, which I'd rather use than moisture-resistant MDF. The other option under consideration is 10mm x 10cm solid quartered white oak over 15mm birch ply, balanced behind behind with 10mm solid and routed out. Obviously, this is much more expensive and time-consuming. I've 33m2 to cover.
12/17/23       #4: Veneer in exteriors ...
Dave Edgerton  Member
Look up parklex panels. Specifically made for this
