Subject: Re: Where there's smoke...
3/8/25
Gary
I just wanted to pass along an " experience " I had on the shaper the other day. I have a wood fence filler that got too close to the spindle during milling and I heard it squeaking from the contact but think too much about it since " I only have one more pass ! " so when I shut off the machine I could see a little smoke coming off the spindle (!) . So I started pulling off the spacers and cutter to help it cool faster. In the process I quickly learned that the spindle was hot enough to burn me ( which it did/blisters still there) and the spacers actually have a special blue color on them. What the ......
Spindle seems to be fine and have run it since. I just hope it didn't do any damage I can't see. NOWWW I KNOW.
3/8/25       #2: Where there's smoke... ...
Hmmm, friction causes heat.
Now you know. Glad it didn't burst into flames.
3/17/25       #3: Where there's smoke... ...
Gary B.
Good reminder to be diligent about noises when we're running. FYI- Nothing dulls carbide faster than heat.
4/22/25       #5: Where there's smoke... ...
Angelan Member
Thanks for sharing your experience! It sounds like a close call. Overheating can definitely cause hidden damage, so it's always best to stop immediately at the first sign of trouble, like smoke or squeaking. Check your spindle and cutters for any signs of wear or deformation and make sure everything is properly aligned and secured before using it again. It might also be a good idea to let the machine cool down naturally next time to avoid burns. Safety first!
4/24/25       #6: Where there's smoke... ...
Daiva Member
Glad that everything's fine!
