Subject: Re: Weinig moulders
Weinig moulders
4/1/25
Marty levin Member
Hello we are looking to invest in a clamp force tester to test our moulder spindles. Was wondering if anyone had any brand ideas to look at? Thanks in advance.
4/7/25       #2: Weinig moulders ...
Dave Sochar
What exactly is a clamp force tester, and why do you need one?
Weinigs are about the best engineered bits of machinery ion this planet, and problems with them are easily perceived, and easily resolved.
4/7/25       #3: Weinig moulders ...
Marty levin Member
A clamp force tester tests the drawbar clamping force. For the spindles to be in spec they have to pull a minimum of 27000nm. We currently rent one from Weinig twice a year but it’s hard to get on the list to use it. I have found a few different brands to buy. I was just looking for some input if anyone had some info.
4/7/25       #4: Weinig moulders ...
Mark
Marty,
You must have HSK spindles on your moulder.
I too didn't know what you meant by clamp force tester.
Mark
4/8/25       #5: Weinig moulders ...
Marty levin Member
Yes. Sorry guys we have HSK spindles.
4/24/25       #8: Weinig moulders ...
Angelan Member
Hey there! Congrats on completing the trans swap on your Bel Air. The issue with reaching L1 and L2 is common when upgrading to a 700R4, especially since it has more gear positions than the old 350. The original linkage often doesn’t support the full range needed for the 700R4.
A solution is to go with an aftermarket shift linkage kit specifically designed for this swap. Companies like Lokar and Kugel Komponents have universal transmission linkage kits that can be adjusted to suit your setup. These kits allow the necessary range of motion to access all gears, including L1 and L2. You might have to also adjust or replace the shift arm on the transmission or the column to ensure full functionality.
Also, ensure all connections are tight and the geometry is correct, as even small misalignments can prevent achieving desired gear positions. Good luck, and hope this helps!
