Subject: Re: Pressure for glue pot dispenser
2/6/26
Al
For those who use pressure tank glue dispersion how much air pressure is needed? Will just be using Titebond Orginal.
Thanks,
Al
2/10/26       #2: Pressure for glue pot dispenser ...
Mark Elliott
We pressurize to 60lbs after filling it, and after we have dispensed some glue, it starts to drop pretty fast. You will find that even at 20 lbs. it will flow pretty good.
Hope this helps,
Mark
2/13/26       #3: Pressure for glue pot dispenser ...
Al
Thank you Mark. If you use it for dowels could you recommend correct tip? Pizzi brand offers 8mm tip. Would you know if this size is slightly smaller than 8mm so it fits into 8mm hole or should I get 6mm nozzle? Also they have different lengths.
2/13/26       #4: Pressure for glue pot dispenser ...
Mark Elliott
Al,
I use mine for edge gluing, so I use the standard handle and tip that comes with the unit.
I would think that the 8mm tip is sized to apply glue in 8mm holes for dowels, so don't go for the 6mm.
If you get one, let me know how you like it, I've been giving some thought to getting one for that very purpose. I'd bet it applies an even amount of glue to the side walls of the hole. I'm not convinced that the tip that applies a metered amount of glue is worth the price. You can accomplish this with the setting that controls the glue flow.
Hope this helps,
Mark
2/19/26       #5: Pressure for glue pot dispenser ...
Joe Calhoon
My experience with pressure is the same as Mark. I have a 10mm tip and it measures about 9.5mm and slides easily in a 10mm hole. I don’t have any metering, just get a feel for the trigger squeeze.
