Subject: Re: Re-skinning Entry Door
4/2/26
Chad  Member
Website: http://www.adamsarch.com
We have taken on a project that I would like to get some advice and feedback on. A customer has asked us to re-furbish several sun & rain worn wood exterior doors for a highly regarded building in our town.
We suggested that we can re-skin the doors. We received the doors, removed the bolection moulding, the glass, and loose pieces. We first were going to take the top layer of the door off by CNC and then we opted to use our wide belt sander. We are as far as removing the top layer. We are now at the stage of applying the new skin made from quarter sawn Sapele. This is where I am looking for advice:
1.) Do we need to be concerned with the moisture content of door compared to newly re-sawn skin? What if the door is dryer than the new skin? What issues can this cause?
2.) What type of adhesive would you use to glue the new skin to the old door? We use Franklins Advantage 405 but thinking maybe we should use an Epoxy like West System.
3.) Need to re-glaze the glass. What caulk do you use to caulk glass in? We use Nova Bond Pro caulk but it is not silicone. I feel silicone is the way to go since it is water proof. But as you know, silicone is it is not stainable or paintable and can be a mess.
Appreciate your feedback
View higher quality, full size image (2142 X 2856)
View higher quality, full size image (1512 X 2016)
4/9/26       #2: Re-skinning Entry Door ...
Monica Chou Member
Website: https://www.zonledoors.com/
1) This is very important! The moisture content of the new veneer and the door core should be as close as possible. A large difference may lead to cracking, bubbling, or warping later.
2) Advantage 405 can actually be used, but its outdoor durability is average. Of course, as you said, using epoxy resin adhesive would be better.
3) If you want a painted effect, I recommend using a paintable sealant (MS or similar).
I hope these suggestions help you.
4/13/26       #3: Re-skinning Entry Door ...
Dan Hahr Member
At what point would you suggest buying a new door...it's damn near rotten...
Dan
4/14/26       #4: Re-skinning Entry Door ...
Dave Sochar Member
Ah yes, I can almost smell it.
I would remove ther door skins and get the door ready to recover. Stack, with 3/4" stickers, the veneers on top of the doors. Build a stack if possible. Weighted. With lots of shop air moving around the stack.
Most importantly, door and skins should be together for about 2 weeks to insure they will all have same MC when applied. Like the hardwood flooring guys - acclimating they call it. Meter as needed. And use West System.
4/22/26       #5: Re-skinning Entry Door ...
BH Davis  Member
I don't think you will find any professional glass shop that would recommend silicone for glazing as it does not have great adhesion capabilities. Stick with an oil based (caulking tube style) glazing product.
5/1/26       #6: Re-skinning Entry Door ...
Matt Calnen
Thank you for letting me know I am not the only dumbass in this world that takes on projects like this! Good luck. You might tell them that after you got into the project, it’s was worse than expected and they need a new door. What you are working with seems like a failure to start with.
