"Structural" Cypress
11/17/14
Brad Member
We have project that a structural engineer has spec'ed a Structural cypress product with a finished dimension of 7.5" x 7.5" x 12' that will be mounted end up (Church Cross). Problem is- None of my suppliers know of any such thing as "structural" graded cypress.
We proposed a balanced lamination to get the thickness and create more stability. The piece will be used outdoors and finished with epoxy/spar combo.
Any ideas?
11/18/14       #2: "Structural" Cypress ...
Rick
Being from the South, "Structural Grade" Cypress is also called "Select Structural" or mostly here just simply called "Select" This PDF should explain it in more detail. http://www.turnbulllumber.com/species/cypress/TechGuide.pdf
Hope this helps.
