How would you go about building this?
1/18/15
mauricio Member
http://incrediblethings.com/wp-content/uploads/2009/05/cardboard-yin-yang-bookshel
View larger image
1/18/15       #2: How would you go about building thi ...
james mcgrew Member
Website: http://mcgrewwoodwork.com
the outer circle is a given, start with your "Back" as a template and either dado the "S" into it or build it separate with a form. I would use either 2 layers of 3/8ths "wiggle wood" (Benda ply) or .125 bending luan laid up in layers.
If you build the "S" up separate then make it a tad long so you can scribe the union nice and tight. looks complex but it is just radius work
View higher quality, full size image (695 X 690)
1/18/15       #3: How would you go about building thi ...
Dan / drbwoodworks
Kerf- core , is much better than wacky wood or bending Luan
1/19/15       #4: How would you go about building thi ...
Kilgore Trout Member
That crazy Internet thing has many articles about this, calling it a cardboard DIY project. I would suggest it is neither DIY, nor should it be made of cardboard.
Basic woodworking materials are available to the professional. Beyond that there is a bit of drawing, first to scale, then full size. All very much within the scope of a professional woodworker.
1/19/15       #5: How would you go about building thi ...
Leo G
Big chunk of wood and some carving tools. LOL
