Reveal strips
3/5/15
Nathan
Hey Guys need a little help. we have several jobs typically in a bank that is requiring that we to reveal strips in the laminate panels. this is how we have typically done them but looking for a better method to for a better quality job and faster.
1-panels are laid up on a PB core with a maple Laminate
2-then machined to have 1/2" wide and a 1/4" deep dado applied to them while the panel is being cut out of the sheet on our nested base.
3- we cut a 1/2" wide x 1/4" PB core with black laminate attached
4-fit this into the dado using wood glue and snugness to hold this into place.
-the problem is that we are finding that we have material thickness problems and so our dado cut on a nested base CNC is changing depth due to the material and we are constantly changing the thickness of the reveal strip to try and get the Black laminate to match up with the Maple Laminate as perfectly as we can. they do not want a recess on the reveal strip and want this to be as flush as possible to the laminate. any thoughts would be appreciated.
3/7/15       #2: Reveal strips ...
I don't know what advantage the 1/4" PBd gives over just using laminate directly. Do some tests to determine what your glue line adds. Water based contact is less variable in thickness. Plain old TiteBond works if you let it get tacky and then use it much like contact. We just use a maple block to drive the laminate insert flush when using the still semi soft TB. Each sheet needs to be touched off on the router so you will get a reasonably close depth of cut. Laminate varies in thickness also. So you have to measure it before hand. Even with all this fooling around there will be a very minor offset sometimes.
