Furry Mahogany
8/29/20
Gary
Does anyone have any tips for sanding the furry/fuzzy places in Honduras Mahogany so it can take a finish well ? Would soaking it with Epoxy and then sanding be a possibility ?
Thank you
8/29/20       #2: Furry Mahogany ...
rich c
No, soaking in epoxy is not a good method. Besides, epoxy has a thick consistency and doesn't soak in. Just dampen the surface with a damp rag and then sand. Species of mahogany would be good information to provide as some places used to sell Luan as mahogany. Genuine mahogany is a dream to sand and finish.
8/30/20       #3: Furry Mahogany ...
TonyF
Gary:
If it is really bad, you might consider a dilute glue sizing, made with Titebond or something like it. But part of addressing this issue with something that is not part of your finish schedule is that there may be variations in appearance if you have to stain your lumber afterwards.
As an ideal, you would select some better quality mahogany to replace the fuzzy stuff, but that may not be economically feasible.
Perhaps the best thing you can do at this point is to brush on some of your finish or finish sealer on the affected areas, sanding it back between coats, until the fuzzy area has become less fuzzy, and then finish as you normally would.
Hope this helps.
TonyF
8/30/20       #4: Furry Mahogany ...
Jack Mazzuchelli  Member
You can try what i do, prior to finish i take a wet,not soaking, and wipe down every surface.Wet but NOT soaking, this will raise the grain and the fuzzies, let dry, then sand.May need to do twice if you lumber is really bad but once seems to work for me
9/1/20       #5: Furry Mahogany ...
Robert Member
Try a Cabinet Scraper, a sharp one !
9/2/20       #6: Furry Mahogany ...
D Brown
We called it Broom grain, we can't change the characteristics of the wood so learn to spot it and try to avoid it.
9/18/20       #8: Furry Mahogany ...
Gary
I posted the original question and have a follow up: I used West System Epoxy , thinned with a little laquer thinner to soak in better, and it worked amazing. Sanded smooth and ready for paint.
    Doucet Machinery
