sawstop brake issue
7/29/22
One of our sawstop table saws shows the brake adjustment error code whenever the splitter / riving knife is not installed.
I tried installing a new brake, but that did not fix the problem.
It also does not fix if I adjust the knife lever handle halfway or all the way down.
Any pointers as to where to look for a solution would be greatly appreciated.
7/29/22       #2: sawstop brake issue ...
Have you called Sawstop? I've had nothing but great service from them.
7/29/22       #3: sawstop brake issue ...
I did, and they got back to me pretty quick. Had to raise the spreader plate a notch or two. Casual
7/30/22       #4: sawstop brake issue ...
BH Davis  Member
Glad you got it sorted. I had the same issue once and found the gap between the aluminum brake plate and the blade was too large. It happened when I changed to an old, repeatedly resharpened blade and didn't check the brake to blade gap.
I also went the other way once and had the blade too close to the brake. That cost me a brake replacement.
In my defense I'll add that I've been with SawStop since the very beginning so these two incidents occurred over a span of many years.
