Melamine warping after cutting
4/21/25
Tyronne
Good day all.
I have already read a thread about melamine warping after cutting that was posted over 10 years ago. I am looking for any advice.
I'm going to use metric measurements.
So the problem is that whenever we are cutting thin, long pieces of melamine, it tends to bow or warp. Now this really isn't that big of an issue, because we mainly use these pieces for cappings, kickplates and fillers. The issue comes in when we are cutting long doors that are 300mm to 595mm.
When 2 doors of the same size is next to each other, the top and bottom touches, but in the middle there's about a 4mm gap. It makes the finishing process so much longer and difficult.
So I was wondering if anybody can help me to understand what we are doing wrong and what can we do to get more straight cuts.
If there's any uncertainty or questions. Feel free to ask.
4/21/25       #2: Melamine warping after cutting ...
BH Davis  Member
Have you tried other materials? If the same thing happens on other panel products then it is a machine as vs. material problem.
4/21/25       #3: Melamine warping after cutting ...
tom gardiner
When I cut long narrow pieces on the saw I will cut oversize then a straightening cut and finally to size. Judging by the date stamps on the sheets I get, the time the sheets to acclimatize after production can be a few days by the time they are on the floor at the distributor. No wonder there is tension in the sheets.
4/21/25       #4: Melamine warping after cutting ...
Acctek  Member
Website: acctekcnc.com
This could be internal stress in the melamine veneer causing the sheet to bow during the cut. Using the correct blade and feed settings may help.
For melamine sheets, use a high-quality three-piece blade or ATB (alternating top bevel) blade with a high number of teeth. Then set a slow and steady feed rate to reduce vibration or heat.
In terms of cutting order, try cutting the larger sections first and the thinner sections last to reduce the possibility of stress accumulation in the middle of the sheet.
4/22/25       #5: Melamine warping after cutting ...
Tyronne Member
Hi BH Davis
The warping happens on MDF as well, but not to the same extent as melamine.
Same with Formica or post form tops. It bows with 1mm in the middle.
4/22/25       #6: Melamine warping after cutting ...
Tyronne Member
Hi Tom
Yeah we usually do that as well. Let us say that we need a filler that's 100mm. We cut it a 110mm and then we edge it. After that we cut it to the correct width. But it still bows.
I'll see if I can post a photo.
4/22/25       #7: Melamine warping after cutting ...
Tyronne Member
Lets see if this works.
4/22/25       #8: Melamine warping after cutting ...
Tyronne Member
Hi Acctek
Thanks for the advice. I'll pass it on to the operators. We will try out a new blade with higher teeth and ATB.
4/22/25       #10: Melamine warping after cutting ...
Al
I recut everything. Plywood not as bad but it can do it also. Problem is you never know until you cut it. When I first starting using a slider 30 years ago I was told to take a 1/4” off of long side of melamine sheet and this would relieve tension and subsequent cuts would be straight, I have never found that to be true. Solid lumber no different, sometimes bow sometimes not. If I’m looking for 2” wide I oversize some, straighten and then rip to width I want.
4/23/25       #12: Melamine warping after cutting ...
Tyronne Member
Hi Al
Thanks for the advice. We have gotten one of the reps from the manufacturer to come and look. He took the old boards and replaced them with a new batch.
It seems to have worked. The pieces still bow, but not as much.
Hopefully it was a bad batch.
4/27/25       #13: Melamine warping after cutting ...
Kevin Jenness
I have seen this bowing problem with melamine especially but also with some mdf and plywood. My solution is to rip oversize and recut straight parts. More work but if that's what it takes...
4/30/25       #14: Melamine warping after cutting ...
Bruce H
I have been using melamine for twenty five years and almost all warps in the cut. My solution it to cut 12mm over size, advance the saw 2mm (beam saw) re cut both edges and then cut for the final dimension. Cross cut after that is usually without the issue. I'd guess because the parts are narrow. A little more effort on the saw results in less issues at assembly.
