Door Idea??
4/28/26
Tom Norton Member
Here is a door style that has peaked our interest for a new front door. But need some advice regarding the "panel". Solid seems like a potential problem.
So advice would be great.
View higher quality, full size image (800 X 1340)
5/1/26       #2: Door Idea?? ...
BH Davis  Member
Are you a commercial woodworking operation or a home owner? Are you looking to build doors like this or find out how reliable this door would be for your own home?
5/3/26       #3: Door Idea?? ...
Tom Norton Member
I am a finish carpenter/woodworker and this will be for our home
5/5/26       #4: Door Idea?? ...
Dave Sochar Member
Tom - First off, buy a copy of my book. Maybe two - one for the shop and one for the home.
I am no longer producing, but a few years ago, the door only in H Mahogany would be about 1900.00. Another $1700 or so would get the frame and two sidelight sash. Includes 5" ball bearing hinges. Excludes - glass finish, and transport. About $6,000 to your door. So to speak
5/5/26       #5: Door Idea?? ...
Monica Chou Member
Website: https://www.zonledoors.com/
We are a door factory in China. From our production and project experience, for exterior doors we usually do not recommend full solid wood panels. While solid wood offers a premium and natural appearance, it can be sensitive to temperature and humidity changes, which may lead to warping or cracking over time.
To ensure better long-term stability and performance, we typically suggest more stable structures such as engineered wood core, steel doors with wood grain finish, or WPC (wood-plastic composite) doors. These options can achieve a similar visual effect while providing improved durability and weather resistance.
5/8/26       #6: Door Idea?? ...
Dave Sochar Member
Monica - You apparently don't have the skill required to make split-proof panels for wood doors. A 5 or 7 ply panel, reasonably made, will not split.
5/9/26       #7: Door Idea?? ...
Wally
Why doesn't somebody answer the man's question. He didn't ask for a price or info on Chinese doors. His occupation does not matter nor does he need someone pushing the sell or their book. Advise him on how to best fabricate the panel.
5/10/26       #8: Door Idea?? ...
Monica Chou Member
Dave - While multi-layered structures can indeed mitigate some of the internal stress in wood, the edge banding process and the weather resistance of the adhesives are often crucial in outdoor environments exposed to UV radiation and direct rain.
Our cautious approach stems from the need to ensure the product remains unchanged for decades across different latitudes. Do you have any unique insights into edge banding and waterproofing for multi-layered exterior doors?
5/10/26       #9: Door Idea?? ...
Monica Chou Member
Thanks to Wally for the reminder. Returning to Tom's focus on solid wood door construction, besides the multi-layered structure Dave mentioned, these three points are crucial for ensuring stability:
1. Moisture Balance: The moisture content of the wood must be treated to match the average annual moisture content of your local area.
2. Floating Panel Structure: Physical expansion joints should be included in the door panel design.
3. Comprehensive Edge Sealing: Not only the surface, but also the top and bottom of the door panel must be rigorously waterproofed to prevent moisture from entering.
Feel free to add your suggestions.
5/25/26       #10: Door Idea?? ...
Mitch Suber Member
Tom, since you ask for advice, before building a unit like this, I would consider David's recommendation to buy his book. That would be $45.00 I think well spent, and maybe save many hours of frustration yielding a door that doesn't have issues in the future. I have found David's advice to be very helpful on several of our shutter projects.
5/25/26       #11: Door Idea?? ...
Dustin Orth  Member
I guess Tom, what equipment do you have available to make a door like this? Have you ever made an exterior door before? If you haven't made one before, gets Dave's book and start playing around with some junk materials to see how its done. Once you've gone thru a few mistakes ( we all make them learning new techniques and styles) then you can decide if you want to spend a good chunk of money on top quality materials to build your own. Don't skimp on the material quality, it will only make you angry in a few years.
