Heating up the shop
11/26/21
Felipe Member
Hello everyone.
I have a medium-sized shop with no gas connection or space for an oil-burning boiler.
I am considering my options for heating up the 1,500 sq ft warehouse.
Do any of you have a good electric heater you can recommend to me or any other type of efficient heater?
Thanks in advance.
11/26/21       #2: Heating up the shop ...
Thomas Gardiner
Depending on your location and insulation an air source heat pump might be the most efficient electric heating and cooling choice. The cheapest option would be a few ductless split units.
Because they are forced air, you would have to ensure effective air filtration
11/26/21       #3: Heating up the shop ...
Dustin j orth
What kind of insulation? If not already, spend the money on the spray foam. Worth every penny vs return of investment as long as your not only renting for a year or two.
11/26/21       #4: Heating up the shop ...
The only electric heater I would suggest is a couple of mini-split units based on heat load calculations. With the mini-split, you also get air conditioning.
11/29/21       #5: Heating up the shop ...
Jim Kolar
I have a 2400 sq ft morton building. Well insulated. I have two cadet eletric heaters that are 3 phase. They heat the shop really well.
12/1/21       #7: Heating up the shop ...
Joseph Eultgen
I have a 60 x 60 pole barn. I have an R38 on all walls exterior and interior. I have an R50 in the ceiling. I have 2 115,000 btu high efficiency furnaces. I've never paid more the 425.$ ffg or the entire heating season here in mid Missouri. I turn it ffg own to 50 when I leave. Even in freezing temperatures it's still 54 when I walk in. I throw on my carhart insulated bibs and turn it up to 64 when imworking inbthe shop.
12/5/21       #8: Heating up the shop ...
Thomas
We use mini splits in our house, they work fine in the house. For our shop we went with a heat pump hvac. Reason for that is that the filters in a mini split are really small. We built a return air plenum that would hold four 24x24 filters. We blow them out every week. After about three weeks you can hear the air whistling through the filters. (reason for blowing them out every week) It really has helped keep the air borne dust down. I would have made the return air box larger but did not realize how much fine dust was being left behind by the dust collector. The CNC and wide belt sander are the worst.
9/21/25       #9: Heating up the shop ...
Gavra  Member
Long tubes mounted high on the walls or ceiling emit infrared radiation. You feel warm instantly when you are in its line of sight, even if the air is still cool. This makes them exceptionally efficient for a warehouse setting, as they are not wasting energy heating empty space or the entire volume of air; they heat the people and objects directly in the area. For a 1500 sq ft space, you would likely need multiple units strategically placed over key work areas.
However, while infrared is excellent for spot heating, you may want a more comprehensive solution for consistent, whole-building comfort. Given your constraints of no gas and no space for an oil boiler, a Ductless Mini-Split Heat Pump System is arguably the most efficient and effective all-around electric solution for your needs.
You can explore options and get a sense of specifications and pricing for these systems at a specialist retailer.
10/28/25       #10: Heating up the shop ...
Daniel French Member
Heating a workshop efficiently depends heavily on insulation and layout. For a 1,500 sq ft space without gas access, mini-split heat pumps are a great long-term investment—they provide both heating and cooling with excellent efficiency. Infrared tube heaters can also be effective for targeted warmth, especially above workstations. Combining either with proper insulation and sealed doors maximizes comfort and reduces energy costs.
    • Impact Search and Placement
    • WOODWEB, Inc.
    • TradeJobPlacement.com
