Thoughts on LED UV‑curing after wood cabinet fabrication
11/20/26
宁宇 Member
Website: https://uvcuringlamp.com/category/news/
> Hi everyone,
I’m looking into UV‑LED curing for finished wood cabinet parts after fabrication. Compared with traditional mercury UV lamps, LED UV generates much less surface heat, which should help avoid veneer warping or discoloration on thin wood substrates.
I’m curious about real‑world shop feedback. Does anyone here run inline LED UV curing for wood topcoats? What are your common pain points? Things like oxygen inhibition, gloss consistency, or matching coating chemistry for LED wavelengths.
Also wondering how well it works on mixed materials, such as MDF and solid wood batches running together on one line. Any practical tips would be appreciated.
Thanks.
11/21/26       #2: Thoughts on LED UV‑curing ...
Zev Sterling Member
Website: https://remodeloscabinet.blogspot.com/
Haven't actually run an inline LED UV setup myself yet, so take this with a grain of salt.
From what I have heard from other shop owners though, the biggest headache is definitely dialing in the coating chemistry. Since LED lamps put out a super narrow wavelength compared to mercury bulbs, standard UV topcoats often wont cure properly on the surface (oxygen inhibition gets pretty bad) unless you switch to specialized photoinitiators formulated specifically for LED.
Also heard the upfront cost of those LED arrays is pretty steep, and if you're doing shaped doors or profiles instead of just flat panel parts, getting even curing without shadows can be tricky. Definitely curious to see if anyone here has made the jump and got the gloss consistency dialed in.
    • WOODWEB, Inc.
    • TradeJobPlacement.com
    • Impact Search and Placement
