Subject: Re: allowing for crown molding
3/4/15
Tom Member
Wondering what is a good formula for allowing enough room for crown molding when uppers run tight to the ceiling? What width do you make your top rail? How do you figure this for frameless cabinetry?
3/5/15       #2: allowing for crown molding ...
JM
That is totally going to depend upon the moulding you are using....is it 3" or 7"
We build frameless and commonly use a 4.25" crown. We set the top of the upper cabinets about 6" down from the ceiling. An L shaped frieze board gets screwed to the top of the cabinets, then the crown connects the frieze to the ceiling. Adjust upper cabinet height up or down to suit the crown height you are using. I have seen kitchens done with less frieze and find it looks too squishy and magnifies ceilings that are out of level, and done with more frieze it looks like something is wrong.
My $0.02 is a frieze of somewhere around 2.5" looks the most pleasing.
Attached link shows a pic.
Crown to ceiling
3/5/15       #3: allowing for crown molding ...
james mcgrew Member
An inch + crown height will allow for ceiling flaw without serious notice.
give it some room !
3/5/15       #4: allowing for crown molding ...
Bruce H
I do something like JM but instead of a L shaped frieze I extend the sides of the upper cabinets up 48mm and the put a flat board on the front to attach the crown to. Seems simpler to me to just use a flat board, end result looks the same. I'd allow a inch and half under the crown, give or take.
    Lamello
