Subject: Re: pre-glued dowels
pre-glued dowels
3/6/15
Eric Wegner
We are using water activated dowels injected into the floors by our cnc machine. At assembly the mating hole in the gable is filled with water 3/4 full and parts are clamped in a press. We are finding that the hold is good, however several days after assembly the hold is somehow compromised and the dowels let go. Anyone out there using pre-glued dowels having this issue??
3/6/15       #2: pre-glued dowels ...
Dave Edgerton  Member
Could be the dowels or too much water. seems like tooo much water to me. We used dowels from hafele and they were not as good as the dowels from richelieu. they should be dark green in colour not light green. The light green ones let go. If you are using a dowel pistol, adjust water or add pva to the water.
3/6/15       #3: pre-glued dowels ...
Mitch Suber
Website: http://subercustomshutters.com
I agree that it sounds like too much water. Could it be over swelling things a bit, then after the decrease of moisture around the dowel area, the wood is possibly shrinking back. It wouldn't take much to cause a failure. I currently don't use pre-glued anymore, but when I did, we used way less water than the amount your describing.
3/7/15       #4: pre-glued dowels ...
Also a vote for too much water. When we first went to doweling we tested several pre-glued ones. None held as well as the doweling glue. We've stayed with the glue. Just have to be meticulous about keeping the system clean. We use a glue injector for the face dowel holes to keep from having blow outs.
