Subject: Re: beaded face frames
beaded face frames
3/20/15
greg Member
I need a beaded face frame system that recesses the bead just below the body of the frame so it does not get flattened by final sanding.
3/21/15       #2: beaded face frames ...
Sea444
Kreg and Sommerfeld both have great system for notching. Beading is simple router bit. Take off the bearing and cut about 1/32 deeper than bearing allows and you have room to sand frames flush. Both systems simple and quick to learn.
3/21/15       #3: beaded face frames ...
JeffD
Not sure if I'm understanding you correctly? Your trying to figure out how to cut the bead shorter? Just make a deeper cut. You can cut the bead as deep as you want to just by adjusting your setup.
good luck,
JeffD
3/22/15       #4: beaded face frames ...
Edi Silva  Member
Website: silvawoodworking.com
Hello Greg
Are you running the bead on the face frame parts, or applying the bead?
We run our frame parts on the molder and we set to cut the bead around 1/16" lower than the flat. That way, when we run our face frames on the sander, the bead won't get flattened.
Edi
