Subject: Re: keaser compessor need your advise to buy
5/9/15
phil v
im thinking of bying a keaser sx5 to replace my 5hp piston compressor is it better at 10 k I want make sure its worth it please share ....thanks phil
5/10/15       #2: keaser compessor need your advise t ...
Kevin Member
SX5 Air Center is a Great Unit
5/10/15       #3: keaser compessor need your advise t ...
Hastings Read
I bought a Kaeser air station last year and couldn't be happier. With rotary screw you do need the make sure it comes to running temperature. We bleed air to make it work a little harder.
We also had a noticeable improvement in the finish, though that was not the primary reason for getting it.
5/11/15       #4: keaser compessor need your advise t ...
Phil v
Hasting ..Can you tell me why it has to come to temperature before operation
5/11/15       #5: keaser compessor need your advise t ...
Hastings Read
As I understand stand it, the air is compressed by two rotating shafts with helical coils. This metal to metal engagement requires lubrication. My dealer told me that under use of the compressor eventually damages the screw and that it needs to come up to working temperature to ensure good lubrication of the rotary screw element.
5/13/15       #6: keaser compessor need your advise t ...
Jim Herron
A rotary screw compressor will also produce internal condensation if under used causing lubrication problems and milkshake looking lubricant.
Not cheap to service or maintain but produces a lot more volume of air than piston pump.
5/20/15       #7: keaser compessor need your advise t ...
Knick  Member
Website: cmsdisplays.com
you need to post more info for anyone to help you. Do you use enough air to warrant a screw compressor? Not sure how big that model is but a screw compressor runs from the time you turn it on until you turn it off. They are for places that use a lot of air
