Subject: Re: finger pull
finger pull
6/22/15
Ron Montbleau
I'm starting on a kitchen where the client wants slab doors with no pulls. What is a good gap for fingers? 1". Maybe 1.25"?
And is a 22.5 degree bevel about right?
6/23/15       #2: finger pull ...
chipbored
Excuse my metric response
We do a heap of this work and we do 25mm (1") reveals. A lot of people do 30mm but architects always ask us for 20mm which is just on the small side so 25mm is a perfect compromise.
We do a 45 bevel and on a flat panel painted door leave about 3mm of meat on the front edge (hope that makes sense)
6/23/15       #3: finger pull ...
Ron Montbleau
That makes sense except for the 3mm of meat on the front edge.
I think I will do a 1" reveal between drawer fronts. But do 1.25" between the top of the doors and the counter because of the overhang.
6/23/15       #4: finger pull ...
Leo G
Why not use a 2-3mm gap with Blum Tipon push to open hardware.
6/23/15       #5: finger pull ...
Ron Montbleau
I considered that. Customer doesn't want pulls on appliances either, so I have to do finger pulls there and I figured I might as well keep it consistent and do finger pulls elsewhere. Also, I'm concerned that with 2 young kids that touch latches would promote getting oil stains on the cabinets in the spots where you touch it open. I'm not sure how valid a concern that is though?
6/23/15       #6: finger pull ...
chipbored
I'll send a picture of what our door looks like to help explain.We leave the tip of the mitre 3mm from the front edge of the door so there is not a sharp edge that could get knocked and chipped.
Have you considered having the door flush to bench top so you can keep the gap consistent? I set the front of door 3mm behind the bench top depth.
Have also done the Blum tip on drawers before. I find that the theory of it is great but in practice they are extra drilling and fabrication work, more expensive, you have to set the doors 3-4mm off the carcass so hard to line up with doors that are sitting 2mm off the carcass, a pain to adjust, and many people don't like the touch to open on base cabinets because if they knock the drawer it opens.
6/23/15       #7: finger pull ...
Ron Montbleau
I have another design issue with the finger pulls at a pair of side by side sub-zero freezer/refer. The client went to a Pirch showroom and saw a side by side setup with a stainless steel C-channel separating the 2 appliances and a 1.5" gap between the panels for finger pulls. I want to do a similar setup but using a wood filler setback instead of the metal channel. Tried to ask Sub-Zero tech support about how to do it and they scratched their head and said they'd never heard of it.
Has anyone tackled this one?
