Subject: Re: Heavy duty pull down closet poles
6/14/15
Chris
I installed 10 of these made by revashelf. The client loaded them up. Some are obviously over revashelf's 25 lb. rating while others seem fine (guessing to what would perhaps weigh 25lbs.) one came crashing down as she (client) must not have been able to hold the apparently over 25 lb. Weight she had hung on the rod. Plastic housing broke (no injuries thank god) I installed the additional "heavy duty" bumpers which flex the 3/4 screwed to 3/4 ply (frameless) sides onto which the mechanisms are attached...sketchy. Is there any manual out pull down rod rated much higher than 25 or so lbs.? I've checked hafele (26 lb.) and sugatsune doesnt have one that fits my 26" interior cab.
Besides, the sugatsune only carries 33 lbs.
Goofy thing is, the catalogs always show 3 to 5 shirts in their pics. 5 dress shirts weigh 25 lbs?
I did see an electric version rated for 75lbs.
Probably pricey not to mention the install.
6/15/15       #2: Heavy duty pull down closet poles ...
Jim Herron
Hardware Resources rates at 33lbs.
The client needs to understand that they can't allow the wardrobe lift to free fall.
My wife broke one the first week in our new house, and I have had some customers let them free fall-turns 15 pounds into 100 fast.
I replaced the customers at no charge, the wifes is still broken....
6/16/15       #3: Heavy duty pull down closet poles ...
Chris
Thanks Jim. I'll check into the hardware resources manufactured one. 33 is better than 25 I guess.
6/23/15       #4: Heavy duty pull down closet poles ...
Rick L  Member
http://www.cabinethardware.com/Wood-Technology-Superlift-Wardrobe-System-p/280526.
htm 40 lb
http://storagemotion.com/wp-content/uploads/2013/09/AWL_spec.pdf
75 lb
6/23/15       #5: Heavy duty pull down closet poles ...
Chris
Thanks Rick. I mentioned the electric one to client (around $600 ea) plus electrician etc. the other link is news to me so thanks a bunch. I'll post some pics of what this client is hanging. Seems too much but I haven't weighed the clothes!??
6/23/15       #6: Heavy duty pull down closet poles ...
Chris
Loaded
