Subject: Re: vertical sliding doors
7/3/15
rich Member
Website: http://www.handmadefurniturecompany.com
I've a client that has a couple of pieces to be built and the designer is calling for the doors over the tv to slide up and or down. They are hoping to avoid the $3k cost that Inca charges. Hafele sells one that is not motorized so I assume its inexpensive but not big enough or our locations. Any hardware you know of that could work please pass it on. Thanks
7/4/15       #2: vertical sliding doors ...
Dan
Hafele offers the EKU Libra sliding door hardware which would allow you to slide one door up and down with a counterweight dummy panel moving up and down in the back, or two bi parting doors moving up and down in the front. Hafele also sells the Salice " Mover" which allows one door to lift up in front of cabinet but door sizes are limited. Neither solution is terribly expensive.
7/6/15       #4: vertical sliding doors ...
This is the "Mover". This coplanar system is available for a door height of 600mm and for widths of 900mm, 1200mm, 1800mm and 2400mm as stock items.
View higher quality, full size image (1123 X 455)
7/17/15       #5: vertical sliding doors ...
rich
Thanx for the feed back.
