Subject: Re: Is there a euro hing
7/31/15
Richard Member
Is there a euro hinge that allows 2 door to swing on a single 3/4 divider?
View higher quality, full size image (500 X 236)
8/1/15       #3: Is there a euro hing ...
Dan
No, but four euro hinges will do it.
8/1/15       #4: Is there a euro hing ...
Rich Kuban Member
Website: http://www.closetexperts.com
You can accomplish this with any major Euro hinge manufacturer. You either use a "half overlay" hinge, or a thicker base plate with a full overlay hinge. Typically the half overlay hinge will have an offset in the hinge arm compared to a straight arm on a full overlay hinge. You will need shorter screws to attach the base plate too.
8/1/15       #5: Is there a euro hing ...
Robert Duff
We use sex bolts to mount the plates to the 3/4" sides. Screws that come with plates are to long, using shorter screws will not give enough holding strength.
8/1/15       #6: Is there a euro hing ...
Rich Kuban Member
I never had a problem using 10.5 mm Euro screws to mount plates in system holes in 3/4 particleboard. I would not use 8 mm Euro screws though with 5/8 material. Definitely would use the double bolts in that scenario.
8/1/15       #7: Is there a euro hing ...
Richard,
Here is the layout using Salice 120 degree, half overlay hinges and 2mm mounting plates. You could also use the tall mounting plate with a full overlay hinge as mentioned above.
The 11mm Euro screw actually extends into the panel 7.5mm. I have never seen issues with this length of screw. If this is a high use, commercial application, the sex bolts wouldn't be a bad idea either.
You could do the same application using a 94 degree, 110 degree or 165 degree hinges as well.
View higher quality, full size image (2882 X 1520)
8/2/15       #8: Is there a euro hing ...
Richard Member
Thank you all.
    Lamello
