Subject: Re: Need help selecting Router bit for my cabinet doors
8/3/15
Ryan [Cabinetmaking Forum] -- [173.209.211.244] Member
Hello everyone first time posting here. Thanks in advance for reading this.
So I build a kitchen pantry for the wife the other weekend and now I need to build the doors but need help picking out the closest router bit set to match out previous doors. I have no experience making cabinets but think I did a pretty decent job. I just need to make another shelf and install the pull out garbage can thing. Thanks
8/3/15       #3: Need help selecting Router bit for ...
Henbob [Cabinetmaking Forum] -- [108.71.160.107] Member
look into buying the doors from a door manufacture, will save you a lot of effort. there are quite a few good companies all within a quick google search
8/3/15       #4: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.237] Member
That would be taking the easy way out. When someone ask me where I got that I like to say I built that. I don't like to hire anything done. I may have another project building a few dressers so I'm going to need a router anyway and when I build my house I'd prob build my cabinets myself if I have the tools. Basically I like to do things on my own. I figured it would cost me just as much to buy my tools than to have them made by someone else.
8/4/15       #5: Need help selecting Router bit for ...
Sea444 [Cabinetmaking Forum] -- [107.196.196.92]
Look up woodline.com. They have router bits for that door for about $100. Perfectly adequate for a couple of kitchens.
8/4/15       #6: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.150] Member
Thanks for the reply but I'm not sure exactly which set I need. I've looked at lots of 3 piece bits but don't know which one I need which is why I came to the site in hopes someone could say here this is just what you are looking for lol. Do I need a 3 piece set, 4 piece set or what do. U think? I obviously am looking for a 3 piece for sure but I'm guessing I need a 4 piece since the outside of the door has some work done around it.
Thank you
8/4/15       #7: Need help selecting Router bit for ...
Chuck Hicks [Cabinetmaking Forum] -- [69.34.68.32] Sponsor - Southeast Tool
I cant tell enough from the pics to tell what bits you need. It does look like a straight raised panel (guess), stile and rail set, and then an outside door profile. You mentioned that you had no experience making cabinets, raised panel bits will bite if you are not careful. Henbob's comment was something to really consider, but I understand about wanting to make it yourself. my2cents
Catalog
8/4/15       #8: Need help selecting Router bit for ...
door shop guy [Cabinetmaking Forum] -- [68.103.198.16]
That is a factory door and you will not be able to find the bits to make it. (the raised panel you will find). I had these cutters custom made and they cost about $700.
Good luck.
8/4/15       #9: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.224] Member
How do I determine if I need a 3 1/2" bit of a 3 1/8" bit for example? This might be a cheap set but I don't want to spend a bunch of money on the bits if I'm only going to build a few things. If I was doing it every day I could see spending a few hundred on a good set but I can't justify it right now. http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=13140726805
6&category=177001&pm=1&ds=0&t=1438699165680
8/4/15       #10: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.201] Member
http://m.ebay.com/itm/3pc-12-w-Back-Cutter-Raised-Panel-Bead-Rail-Stile-Router-Bit
-Set-sct-888-/131408866939?nav=SEARCH
Something like this??
8/4/15       #11: Need help selecting Router bit for ...
Ryan,
You need to know what the reveal is on both to find out what you need first.
8/4/15       #12: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.154] Member
Do I measure from where the raised panel starts to the stile?
8/4/15       #13: Need help selecting Router bit for ...
The reveal is where the angle or radius stops, but you have to measure the flat also. The part that goes into the stile and rail.
8/4/15       #14: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.194] Member
Ok thanks. That's what I was figuring you were going to tell me.
8/4/15       #15: Need help selecting Router bit for ...
Ryan [Cabinetmaking Forum] -- [173.209.211.157] Member
Ok thanks. That's what I was figuring you were going to tell me. I will have to check it tonight when I get done with work
