Subject: Re: Storing cabinets over the winter
8/17/15
Kevin Member
I have a kitchen coming up that will be completed in the fall, but due to some issues with the homeowners, would not be installed until the spring. I am considering building now and storing the cabinets over the winter, but am a little nervous doing so. Would it be better to store them finished, and maybe reduce some movement, or let them do their thing over the winter, then sand and finish in the spring? The finish is white cv, and I'm nervous about cracks showing at the glue joints on doors and face frames. My shop is heated, but unless I'm spraying, I usually keep it maybe 55-60. There is currently no humidifier, but I suppose I could add one. Any suggestions?
8/17/15       #2: Storing cabinets over the winter ...
Robert
Kevin,
You will most likely be fine if the shop is a consistent 55-60. It the constant changes OR if stored unheated the gain in humidity OR if stored unheated the freeze thaw cycle. We've stored unheated for 2 months w/o problem in winter (cold area, not temperate coastal areas) and we've stored through winter in 50 degrees heated, both w/o problems. After finishing, wrap in paper (to protect from long term storage of plastic next to finish) and then wrap in plastic. That will really slow down any humidity changes. Good luck-
8/18/15       #3: Storing cabinets over the winter ...
I'd almost be worried more about getting fully paid than the storage. Take them offsite in a climate controlled storage. Add the cost to the job.
8/18/15       #4: Storing cabinets over the winter ...
mark
Storing cabinets isn't a good idea, unless the storage environment is controlled. Maintaining consistent RH is most important, but avoiding temperature extremes is a concern as well. It is also important to let the finish fully cure (2 weeks?) before covering.
8/18/15       #5: Storing cabinets over the winter ...
I wouldn't build them until I needed to. But, it'd be nice to do it if you had some slow time. I've had jobs that didn't get out the door like they were supposed to, and I had to sit on finished product for a while. It almost always ends with something being dinged, and something bad happening to them, and more work being created.
But, if you've got somewhere clean, temperature and humidity controlled that's safe, and preferably with no risk of UV damage as well, I'd say go for it.
8/19/15       #6: Storing cabinets over the winter ...
Kevin Member
Thanks for the responses. I have decided against trying to store them. In the mean time, the homeowner is considering letting us do the work this winter after all.
11/17/15       #7: Storing cabinets over the winter ...
MarkSindone  Member
Website: http://supercheapselfstorage.com.au/facilities/syd...
Glad that you came to a decision that works for you mate! I know the thread is closed, but just to add my 2 cents worth (and not in the technical terms, but more on practicality). You'd be better off making and finishing the cabinets closer to your delivery date. Even if you had the space to keep them, heaven forbid that something happen to the cabinets while in storage over the winter and you have to do something to fix them before delivery!
