Subject: Re: Questions on construction/line boring….
9/14/15
JeffD
I've been using an older CNC drill for all my line and construction boring for the last few years. It replaced my previous method of using a Powermatic line drill and biscuits and screws, and has been a great piece of equipment. Since moving to my new shop last year I have not been able to get the CNC up and running. Luckily for the last year I've been busy with everything but cabinetry, but that's changed and now I need to resolve this situation. I have a tech coming in the near future from a couple states away, but he's not overly optimistic my spending a lot of money on a 30+ year old machine is the best way to go…..can't say I blame him. So in the meantime I figure I'll start doing some homework on drilling options.
Sooooo, what makes/models have you guys used and what did you think of them? I'll probably be going used but it's always good to know what to avoid and/or what to aim for. Right now I'm thinking if the CNC does turn into an anchor, I'll look for a double row line boring and separate construction drill. Don't want to waste time changing bits constantly. Anything else I should look for?
thanks,
JeffD
9/15/15       #2: Questions on construction/line bori ...
Rich Kuban Member
When your business is custom closets and you promote adjustability, you drill a lot of system holes. Over nearly 30 years, I changed saws and edgebanders, but the one machine that I never replaced was my Gannomat Systemline. It had two 23 spindle drill heads. I had a tech modify it so I could half or through bore with the flip of a switch. Finally sold it to a guy who replaced a Vitap machine with it. I replaced contactors, switches, and air lines, but the repairs were fairly inexpensive. Rebuilding the drill heads is not cheap, but if you DON'T over lubricate them they last a long time between rebuilds..
    Lamello
