Subject: Re: problems with line borer
10/8/15
Kevin Member
I recently picked up a conquest mini 13 line borer. Seemed like a good fit, not too expensive and as I build face frame cabs, it would be for shelf holes only. I just can't get consistent results. Part of the problem is long runs of shelf holes. Although I try to hold the piece tight while engaging the index pin, small errors seem to compound, leaving me with mis-aligned holes. I also sprung for digital flip stops left and right, but it seems as though I am constantly checking and adjusting those as well. Is there something I am missing with these machines? I am close to going back to a drill and plexiglass jig, slow, but never had the poor results I am getting now.
10/9/15       #2: problems with line borer ...
door shop guy
I had the same problems on a brand new Conquest same as yours about 4 years ago. Lets say you drill a line of 13 holes and only want to drill 6 more holes...plunge the index pin and drill and you are redrilling some holes. Well mine was wallowing out the holes so the spindles were not aligned. I thinkered with that machine and did a crazy amount of test pieces and finally i had to return it to the dealer and bought a Delta and it is perfect dead nuts on quality.
The guy at Conquest acted like he had no idea what i was talking about.
10/11/15       #3: problems with line borer ...
Jim Herron
Remove the indexing pins and try an extended back fence and multiple gravity stops set in multiples of 13x32mm.
