Subject: Re: Hood access
Hood access
10/19/15
Carmine Member
For those of you that build their own hood enclosures. Do you design them for access to allow for an easier install/connection of duct work and for any future replacement.
I often find I need to sacrifice a little on the design details if I allow easy access.
Do the pre-made hoods allow access
10/21/15       #2: Hood access ...
csaw
Website: http://www.hofmannjoinery.com
Lamello Tenso connectors work for this. They snap into place and hold with 35 lbs. clamping force. If you keep the connection back from the edge a bit (so you can get some purchase), you can remove something like a valance or hood. They have cam-locking connectors that are even stronger too, you just need to have access to the cam lock (tiny hole on back face).
Lamello Tenso
10/21/15       #3: Hood access ...
Chris
We just did this as the electrician told us it was code. I'd be interested how others do this. What we did was to build the enclosure and rely on right and left flanking uppers to screw into the enclosure. It worked but it did sag a bit 2 weeks later (caulk joint...less than desirable and needing to be cut later if you needed access to blower etc.) we thought a door would be least brainy but the designer didn't want to see the thickness of an overlay door...whatchagonnado? Though I fully understand the Tenso....how do you apply it to this application?
10/22/15       #4: Hood access ...
csaw
You have to make the slots for the Tenso with a special machine, the Zeta. You'd just run the slots in the location of the connectors on both the hood/access panel/whatever and then on the mating side of the surround/cleats/cabinet. If you have the ability to get some purchase behind the hood or panel, you'd be able to pull it off with some effort using Tenso. If it needs to be really strong if it's a heavy hood, use the cam-clamping connector - Clamex. See video.
Lamello Zeta P2
