Subject: Re: "Combed" wood
"Combed" wood
11/6/15
Cabmaker
A customer was asking about something he'd seen called "combed" wood.
He liked the texture of the material but was concerned about how difficult this might be to clean. He thought the modulations in the surface might be too deep to wipe down with a cleaning sponge.
Can anybody recommend where to go so I could learn more about these types of panels?
11/6/15       #2: "Combed" wood ...
Leo G  Member
Website: http://www.lrgwood.com
Sounds like wire brushed wood which removes the softer grain leaving the harder grain raised up.
Or possible sand blasted wood. Same thing, slightly different look, same concept.
11/6/15       #3: "Combed" wood ...
joel
Sign companies use red cedar and sand blast for this effect. Never done the sandblasting but it comes out pretty cool/.
11/6/15       #4: "Combed" wood ...
Chris
A brush sander will create this effect in woods and in thick veneer. Textured melamine panels offer the same look. We just did a big kitchen with this product. Depending on what you're after, it might be the ticket. Some think it's not wood and therefore inferior, others like the look.
Clear Metro collection
11/8/15       #5: "Combed" wood ...
Dan / drbwoodworks
We did a job with white oak that we used angle grinders with wire wheels . I will try to post a picture. And yes it is impossible to clean , with the white oak anyway .
11/9/15       #6: "Combed" wood ...
Pete Anderson
Website: petesfloors.wordpress.com
Siding, made like shingles has been wire brushed with a special machine and gives texture to the look.
Flooring that has been wire brished at the factory has some of the same look.
To clean the surface you would need to dissolve the soil and rinse it away using the correct solvent, either water or mineral spirits, with some detergent to help the lift the stain. A scrub brush will help to get everything below the surface.
11/15/15       #7: "Combed" wood ...
Russ
Website: http://www.mr-moulding knives.com
Cabmaker
Well here is an option for you in the link below on page 15 of our shared catalog. They are called combing knives, they have vertical grooves on the face side, you sharpen them just like straight knives for you moulder, the vertical grooves on the back side will give you the pattern you described above.
I hope this helps
All the best
Russ @ Mirror Reflections Inc.
https://www.mr-moulding-knives.com/documents/mirror-reflections-tooling-catalog-2014-2015.pdf
