Subject: Re: sharpening a card scraper
11/23/15
Dan Cook
Yeah, I know I should know this by now, but it has always eluded me. I flatten the edge on a diamond stone. When I raise the burr on the edge with the burnisher I get a burr, but it is not sharp. So instead of shavings I get sawdust. I have watched videos etc. but I must be missing something. what is the trick to get the burr to be sharp so it cuts instead of just riding on the surface.
11/23/15       #2: sharpening a card scraper ...
mike Member
Maybe your trying to hard to get the perfect edge. Maybe your actually or accidentally rounding the edge so when you feel the bur it is not sharp. I put mine in the vise flatten the edge with a fine file, just a few swipes will do it then i lay it flat on the bench and hit the face a few times then put it back in the vise and roll the bur. It's i quick test to see if you can get a sharp bur. You might even like it this way then later on refine to the way you were doing it before to get a better cut.
11/24/15       #3: sharpening a card scraper ...
Cabinet scrapers are great tools, too bad people seem to struggle with sharpening. First you need a good one, Sanvik? Put it in a vice with soft jaws (aluminum angle pc.)Take a sharp fine file and make a square edge. If you feel a bur, it is best to knock that off with a fine stone, flat to the face of the scraper. Take the scraper in one hand and with a smooth screw driver shaft, slide along the edge at about 5 to 10 degree angle with just slight pressure. Don't over do it or the edge will turn too far. One or two light passes per edge. Test on your thumb nail. Should make a nice curl. To use, most people will tilt the blade over too far and pull the edge off. You want to tilt the blade just slightly more than the angle you burnished to. Put a very slight bow in the blade with your thumbs. You can either push or pull. If you did it correctly you will get wide rolling curls that you can see through. If there are planer ripples tilt the blade at an angle to them.
All the fooling around to hone an edge is only worth it if you are trying to smooth a finish. IE take the orange peel out.
You can resharpen the edge several times by just laying the blade flat and burnishing the edge away from the edge. Then do the edge burnish again. Each time you do this it lasts less time. So, 3 times +_? Then it is back to the file.
Most common errors: poor file job, file should be sharp & almost parallel with the blade. Before you burnish, the edge has to be smooth and nearly a perfect 90 degrees. Most people put too much pressure and angle on when burnishing. That will roll the edge too much and make it weak along with requiring you to tilt the edge into the work at too much of an angle. Tilting the blade too much and putting too much curve into it while scraping. Too much angle ruins the hook. Too much curve makes hollow cuts and doesn't take advantage of the flattening capabilities of the blade. Less is more!
11/30/15       #4: sharpening a card scraper ...
Jim Lewis
A sharp scraper (that cuts well) rarely feels sharp. A shaper that feels sharp either won't cut or won't cut for long.
11/30/15       #5: sharpening a card scraper ...
"A shaper that feels sharp either won't cut or won't cut for long." Because it has too much hook! Go easy on that burnishing!
11/30/15       #6: sharpening a card scraper ...
Dan Cook
I got it! I was trying too hard and I think I was rolling on too steep of an angle causing to to roll over. After reading all your posts I went back and tried again and got it right the first time! Been scraping ever since...it worked like a charm. Thanks to all! I'm living proof you can still learn new things.
