Subject: Re: notching 2x4
notching 2x4
12/8/15
Dave Franklin
Hey,
I've got a recurring job for a neighbor where I need to notch 2x4's together. I've been using my dado set to make the 1.5W x 1.75D notch I need. Wondering if there is a better way to do this? It's exhausting running 150 pieces for each job.
12/8/15       #2: notching 2x4 ...
Radial arm saws were often tooled to do this type of work. Today, one would need to have a cutter made to mount on the Radial Arm saw. $300 to $400 and you can do it all day in one pull.
Today's solution would be to gang all your parts together and mill the grooves on a CNC.
Are you making lattice?
12/8/15       #3: notching 2x4 ...
Dave Franklin
I'll probably end up running them on my CNC. I'm already doing that for the 4x4's for the same project. But it's a bit time consuming because I have to screw down each piece at either end to hold them down. I don't have a vacuum system.
12/8/15       #4: notching 2x4 ...
JeffD
Vacuum clamp would be the preferred way, but can't you utilize a couple DeStaco clamps and several strategically placed stop blocks in the meantime? Screwing each individual piece down is really counter productive.
good luck,
JeffD
12/8/15       #5: notching 2x4 ...
Dave Franklin
I do have stop blocks on all 4 sides, but I also have to add screws thru the stop blocks into the 2x4's. The force of the bit pulls the pieces up without it.
12/9/15       #6: notching 2x4 ...
james mcgrew Member
Build a jig with clamps for the 2x4 and screw jig down one time
12/9/15       #7: notching 2x4 ...
What are you using for a router bit?
I do a lot of this kind of stuff with down spiral roughing bits. I use 3 flute but with the cut length that you have, I'd use 2.
For hold down, bolt 2 machinist vises to the table, one for each end of the 2X4. Clamp in as many 2x4's as you can and go to it.
http://www.ebay.com/bhp/kurt-milling-vise
As long as the bottom of the cut in the 2X4's is higher than the top of the vise jaws you don't need to worry about potential crashes.
12/9/15       #8: notching 2x4 ...
Bruce H
Trying to hold them on a CNC, a pair of these fastened to the table might work. They are big enough to hold your 4x4's as well.
Drill Press Vise
12/9/15       #9: notching 2x4 ...
Dave Franklin
Bruce,
That vise looks like a good option.
thanks
12/10/15       #10: notching 2x4 ...
Bruce H
Dave, I have one of these and they are OK for the money. For your CNC a pair of them just might work. I use mine on a mill/drill.
