Subject: Re: mobile machine bases
1/8/16
scott
Not sure I have this in the right forum, but my question is what size of equipment or what type of equipment would you put in a mobile base? I have a shortage of space and the equipment I had in mind were a 37" wide belt sander, 20 inch planer and 16 inch jointer. Looking for any info? thanks
1/9/16       #2: mobile machine bases ...
james mcgrew Member
Website: http://mcgrewwoodwork.com
In a smaller shop and even now in a larger shop. most all you mentioned it movable, some on small pallets that can me moved with a pallet jack or forklift when needed.
We are a primary laminate casework and desk shop, the sander (37") joiner and planer are not needed most of the time.
1/9/16       #3: mobile machine bases ...
We have several machines that aren't often used, mounted on 4 X 4s so we can move them with a pallet jack. Better, I think than mobile basses. Sit solidly on the floor. The tools you list are heavy but easily moved on a pallet jack.
1/9/16       #4: mobile machine bases ...
dustin orth
I second the 4x4's. A pallet jack in this case is very handy. One other thing I did was go to Harbor Freight and get 4 trailer jacks and mount them to the 4 corners of my big 10 Hp tilting Extrema shaper so when I have to do those really weird things I can move it easily even though it weighs almost 1700 pounds. I just lift it up enough to slide the pallet jack under it, move it where I need it to be and set it back down on its normal feet to keep vibrations to a minimum.
