Subject: Re: Cutting melamine
Cutting melamine
5/6/16
Walter Koch Member
New closet business, trying to get a handle on chip free cutting of melamine. Anybody have a response to a curious/backwards observation? When using a Forrest Hi AT 10" 80 tooth, botting chipping is not as much problem as on top. Even more weird, the higher I adjust the blade, the less chip on top. Would stiffeners help, or what am I not getting?
5/6/16       #2: Cutting melamine ...
You are getting a change in attack angle when you elevate the blade. The contact point of the tooth to the melamine is more vertical when the blade is low. Stiffeners won't change this condition. Keep a fresh zero clearance insert in the table saw, and keep raising the blade till you get the cleanest cut.
5/7/16       #3: Cutting melamine ...
Mike Member
That angle of attack is the rack of the tooth. Start looking at different blade racks to improve this.
5/7/16       #4: Cutting melamine ...
Mike Member
Also try triple chip instead of alternating bevel.
5/7/16       #5: Cutting melamine ...
Walter Koch Member
I truly appreciate the quick replies. One more question, does rack refer to hook angle?
5/7/16       #6: Cutting melamine ...
RicharP
Get a saw with scoring! Anything else you do may help a bit now and then but blades will seldom be sharp enough to give long term great results.
Richard
5/7/16       #7: Cutting melamine ...
Chris
It's rake angle not rack angle
5/7/16       #8: Cutting melamine ...
Leo G
When using a Hi AT melamine blade you have to balance the height of the blade with the wear of the blade. With your first rip into the sheet it's likely that you can keep the blade about a 1/4-3/8" above the stock. But as you keep cutting the carbide will dull and you will have to keep raising the blade.
As you do this you will start to notice more chipping on the backside. When you can no longer keep a chip free back you need to change the blade. They don't last long, 6-10 sheets depending how many passes you do..
If you are planning on using melamine as your standard sheet good, then you will need to invest in a scoring blade saw.
I think they make an insert that will put a scoring blade into a normal saw. It's called the Modulus or something like that.
5/8/16       #9: Cutting melamine ...
Dave L
Reduced/0/Negative hook (rake) blades minimize bottom blowout (and increase feed back pressure) because they reduce the downward cutting angle of the teeth. The more the teeth can face forward as they exit the material, the cleaner the bottom will be. The flip side is that if the entry angle is too steep (blade too low), the top will chip. It's a balancing act, raise the blade only until there is no top chipping. As has been said, that sweet spot will change and the blade will need to be raised as it wears.
While HATB may provide a slightly better initial cut than TCG, cut quality deteriorates quickly. The higher the ATB angle, the faster it will wear. Triple chip blades provide a more consistent cut quality and last a lot longer (twice as many squarer corners to wear).
5/9/16       #10: Cutting melamine ...
Dave B
If you're cutting more than a few sheets per day, consider a vertical panel saw. They are perfect for cutting rectangular parts and are faster and safer than a table saw. The saw moves through the material, not the other way around, so you get a good cut quality and blade life is also extended. You can score the panel either with the main blade or a scoring saw. A Striebig is best if you can swing it.
